P0430 Help
![Angry](https://www.jaguarforums.com/forum/images/icons/icon8.gif)
Hello,
I need your help. I purchased a 2002 X-TYPE v3.0 many years ago for my mom and it is up for (Ontario) emissions testing due by the end of August. The car has a check engine light and it is reporting P0430 catalyst below efficiency bank 2. The local Jag dealer quoted $1800 to fix the issue by replacing the cat. What a rip off!
My mother cannot afford a $1800 repair but she needs to pass the emission test. How do I get rid of the code so that I can pass the emission test? Should I get O2 simulators?
Lastly, is this an O2 issue or cat issue or something else?
Any help is appreciated with this issue. Thank you in advance.
D
D
Hello,
D
D
You have to remove your O2 sensor. It's much easier with the correct socket which you can buy at a reasonable price. Screw in the spacer, then screw in your sensor. Done! These have worked for me. I replaced an O2 sensor and the CEL came back on after about 50 miles. Then I put a spacer on later and CEL never came back on. That was about 2500 miles ago.
juwels365
12-07-2018 02:29 AM
dia_cero2002
09-23-2011 10:45 AM
mtfife
01-21-2011 05:41 PM
