P0447 even with air purge valve replaced
I am also dealing with my EVAP Code, P0447, along with my brake issues.
With the code, I replaced the Purge Air Vacuum Valve and, had the shop check the connector for continuity/resistance, it passes. The code comes back almost immediately. Is the canister purge valve near the gas tank easy enough to replace and available aftermarket or do I have to go OEM?
I also see the canister close valve might be a fault too, is it worth replacing that too?
Thank you.
Thank you.
