P0575 Speed control input, P0571 Speed control brake switch circuit failure
Hi,
Have had these error codes for ages, and cannot be cleared. I have th JLR Mongoose cable and SDD v131, and also a foxwell scanner/reset tool.
I am just trying to resolve the error codes as follows: =left
=left
P0575 Speed control input=left
P0571 Speed control brake switch circuit failure=left
=left
only thing is, I actually don't have cruise control, which is what these point to.=left
=left
I know there are two switches on the brake pedal, and one on the clutch, but even though I have the basic classic model without cruise control should these codes exit? or is it something that would occur anyway of you actually don't have cruise control.
Note that there are "spare" sockets for if it did have cruise control, i.e. so mine never had it, and not of the parts are there.... yet get the above error codes. noting also that the brake lights do work ok, it was suggested that using LED bulbs would maybe cause this issue, but I am using normal bulbs.
I also disconnected the trailer socket lighting adapters, (i.e. that go on the proper harness plugs) but still the same.
Note everything does actually work. it is just these codes are really annoying.
Note I DO now at least have the full X400 wiring diagram pdf... via this forum... so at least my next step is to check all plugs, and any "unused" ones to see if anything is grounding to earth that shouldn't.
Note though, in around 2012 I had my ECU firmware flashed to the latest version by the Main *********** to resolve the injector issue that causes "kangaroo" fuel at 55mph.... since then I have had new injectors anyway, and coded these myself using JLR Mongoose and SDD so they are at least ok.
Maybe the "new" firmware was meant for cruise control vehicles? i.e. later models? there seem to be no way in JLR SDD to tell it that it "hasn't" got this an accessory etc... (ie like you can add/remove accessories, but cruise control is NOT an item listed..
Thanks.
=left
=left
=left
Thanks.
thanks for replies. Yes, it is standard UK spec.... Classic which was base level.... has virtually none of the toys and has a bog-standard non cruise controls steering wheel. I think now I have the correct JLR wiring diagrams I will simply trace the correct plugs and just see if anything is shorting out... starting with the ends of the "unused" connectors etc. and for example the "spaces" where the extra pedal switches would have been.
The only DTC code was E511... but this maybe a red herring, though googling that found someone who replaced a front strut and had that code appear... so hence speed sensor related
the Foxwell scanner and JLR SDD131 both identify P0575 , P0571
there is nothing on the dash codes indicating P0575 nor P0571
I have just had a good search under the dash, just in case there has being something odd in the past been modded.. but looks like there are no spare plugs etc. for cruise control, i.e. although there is clearly an extra set of holes above the brake pedal for another switch, there are no spare/redundant plugs anywhere, including the one under the light switch. it all looks fairly original.
and checking against the 921 page powertrain pdf doc I have......
P0575 Speed control input circuit
Speed control steering wheel switch circuit: high resistance Speed control steering wheel switch circuit: short circuit to ground Speed control steering wheel switch circuit: short circuit to power Clockspring failure
Check the speed control steering wheel switch and circuits. Refer to the electrical guides. Rectify as necessary. Clear the DTCs, test for normal operation.
(yet I do not have steering wheel switches.. as discussed earlier in this thread...)
and there is nothing for error code P0571 in the manual...
Correct, everything else works fine, no other problems, just the two codes that appear for both the Foxwell Scanner and the JLR SDD software.
Maybe it is a red herring.... potentially to do with the fact I have much more newer firmware in my ECU (i.e. circa 2012).
(though odd that no one else has had these same codes.)
I might just have to live with it then.... though I am planning to keep my X-Type even if I get a newer vehicle in the future etc. as its now getting to Classic status (every year there are getting less and less on the road.... and the ones you do see are normally in mint condition with someone who is looking after them....), and I would be gutted in 15 years time if I had let it go.... much the same as I am pleased I kept my original 1991 200Tdi Discovery...…
DAVESPACEBAT (03-21-2019)
djpxk8
09-19-2017 09:03 PM
