p1000 code... obd not ready?
Hope everyone's doing well this Friday... Here's what I have 2002 xtype 2.5 standard.. Check engine is on.. Abs aswell.. P1000 code comes up with bluepoint scanner. Ran emissions test came back as follows: catylist monitor - NR .... Evap system monitor - NR....02 sensor monitor - NR.... . O2 sensor heater monitor - ready. Any suggestions
You will always get either:
P1000: OnBoard Monitoring Tests not completed since last memory clear
OR
P1111: OnBoard Monitoring Tests completed
As you complete the required drive cycles, the P1000 will be replaced with P1111.
With the CEL showing, I'd expect to see other Pxxxx codes stored or pending ........
OR
Not sure.. When I bought it I had to call jag for the correct pin number BC the stereo was locked.. A shop scanned it for me and NO codes came up even with the light on. So he shut the light off only for it to come back on. I bought a bluepoint scanner and that's kinda where I'm at now.. I tried the drive cycles this morning but they are all still Not Ready except OH..
bharvey622 (08-04-2013)
hey guys its been a long weekend lol.... so a little update.. all of the monitors have become ready Except "O" and "CC".. and it was actually because i left the ignition on the #2 spot for a few minutes to plug scanner in and when i checked most monitors are ready..and they have all stayed this way so far today.. im really becoming lost here
Someone on here posted that the memoscan was a good scanner for xtype.. I picked one up online so I will wait for it to come in.. Also the abs light is on and say DSC system failure.. Although the scanner will read abs it says the car won't support it.. Could that have something to do with the CEL? Also thanks for all of your help!!!
Update: I borrowed a friends snap on global scanner and viewed the live engine data... All monitors are ready except "c" and "o" still... But bank 1 sensors were going crazy with reads.. They were as low as -1500s to + 1500s.. Could these two be the culprits? And if so is there an inexpensive sensor to replace them?
Jaguar Forums Editor
Jaguar Press release
09-25-2015 11:58 AM
