P1647, Any Help it's not the O2 Sensor
RE: P1647, Any Help it's not the O2 Sensor
Tony,
H/W is the answer from a tech as to checking the HO2 sensor.
Hope this helps....
As the O2 sensors have been changed, next step is to test the connection to the ECM (he should measure the wire impedance*), and if this is ok, then I'm afraid the ECM may have a problem, which is rare but happens some times...
*Don't know precisely the wire impedance, but there's no need to finely analyse the values: it's just to see if the signal can be distorted by a problem on the cable or if the cable is ok.
Guest
Posts: n/a
ReidWings
08-06-2015 01:42 AM
