Parking Brake
Parking Brake
My parking does not work, this has been going on for a while. My mechanic this past weekend replaced both rear calipers and pads but the parking brake still does not work. He said it might be the cable but as far as he can determine there is no adjustment to take up on the brake. Can anybody help us I looked through the treads and couldn't find any threads on parking brakes. Thanks a bunch.
Last edited by Adam Lueb; 04-19-2016 at 04:36 PM. Reason: add text and correct spelling
In orderr to adjust the emergency brake you will need to pull the handle and release it about 15 to 20 times before you will begin to feel a response. The adjustment is in the caliper/piston assembly.
With new calipers the adjusters should be free and you shouldn't have a problem getting them adjusted.
I know as mine is rusted up!
Parking Brake
The park brake mechanism is located on the back of each caliper. You have to ratchet out to caliper piston until it will set. That is the actual park brake. In old calipers the mechanism gets corroded and sticks, that should not be a problem with new calipers. The slack adjustment is not for cable length it is to balance the cable so that calipers engage equally with the balance bar.
Since you had new calipers installed the pistons and emergency brake mechanism are not yet set. Try the handle method before exploring the cable.
Adam , very simple test to find your problem
With the wheel off , undo the cable from the rear of caliper , pull the lever that the cable was attached to ....... ,
If the wheel locks your calipers are fine ,
If the wheel spins your calipers are the problem .
I can't see why your mechanic has not done this .
Oh by the way , pulling on the hand brake lever up to 20 times is incorrect , there is no adjustment in the caliper for the h/brake , and the hand brake operates from the piston depth
Mastersid, you are partially correct you can disconnect the cable at the caliper and check for actuation. The BUT is since the calipers are new the pistons will come retracted to the inner position. They will brake just dandy but the park brake won't work. The lever on the caliper is a ratcheting mechanism that turns the piston the proper direction to extend it until pulling on the park brake handle sets the caliper.
I have attached the details from the tech manual. NOTE you must pull up on the handle several times to set the self adjuster. Very few of the cars came with the manual adjusting park brakes ( which are the single cable with adjusting rod.
Adam just go give the handle a few strokes and see if everything gets better.
Parking Brake
Thanks for the interesting read.
Adam
Adam , steel is very hard to stretch , do you really think your cables have stretched to the point where the hand brake can't be activated .
If your going to show your mechanic the down load that avern1 posted , you and your mechanic are both wasting time .
There is nothing in that down load that explains how to set your piston depth .
I would suggest you seek a mechanic who understands how that type of hand brake works , clearly yours does not .
Have a good day ,
Sid
Have a good day ,
Sid
A couple of threads ago I mentioned I pulled the parking handle so far up it pulled the gaiter away from the console. I noticed inside the console and attached to the parking brake handle there is a ratchet with a screw on top for turning the ratchet. Any ideas what this is for. As always thank you.
Parking Brake
What gets me this should be a simple repair. I watched all the videos on you tube on the Mondeo rear caliper replacement and adjustments and it does not look like rocket science, but then again it is a English car.
PS If he needs to take the gaiter off and brakes it he pays for a new one.
Received 2,626 Likes
Parking Brake
I hesitate to take the gaiter off, the last time it was off the bracket that connects to the console is very flimsy plastic and broke several tabs. I had to buy a new gaiter at a cost of $90 including shipping. I did try to take the present gaiter off, however I did so gingerly and could not disconnect it from the console, so that screw is a mystery I guess. My mechanic is going to work on it again this weekend, as I need to have inspection done and it won't pass without a parking brake.
There are several TSBs for the early X400 Park Brake faults.
I was going to respond but since the exact make, model, year was not specified, I did not feel like wasting time.
Check the TSBs to see if they pertain!!!!!
I'll post them if they apply but I can't tell.
Look them up in the large file area.
bob
bob
