Parking sensors problem
Long continuous beep is parking sensor malfunction. Use the search function in this forum.
EXAMPLE =
https://www.jaguarforums.com/forum/x...arting-195560/
EXAMPLE =
Received 3,887 Likes
Kuba, the only check that you can really do is replace the module. There are no checks that you can really do unless you are very knowledgeable with electronics and hten you would need to get a schematic for the module (good luck in finding that). You are down to an either/or situation. You either have a bad module or a bad wiring harness. The modules fails a lot more than the wiring harness does.
Bkny85
02-19-2014 09:43 PM
