Part number for front turn signal bulb?
I decided to replace my amber turn signal bulbs with some SilverVision bulbs, to get rid of the "fried egg" look. According to my owners manual it should be the same bulbs front and rear (PY21W). However, the turn signal bulb in front is different, it has a rectangular base instead of round.
Anyone know what bulb I need? It's not a job you want to do over again. My X-Type is a 2002 model, but was actually built in 2001.
copy and paste off of sylvania's website
2002 JAGUAR X-Type (With halogen capsule headlamps)
Low beam headlamp
H1
H1ST Silverstar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
H1XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
High beam headlamp
H1
Parking light
2825
2825LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Front turn signal
7507
7507AST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
7507LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Rear turn signal
7507
Tail light
5007
5007LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
7528
7528LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Stop light
7528
High mount stop light
2825
H21W (64136)
Fog/Driving light
H1
License plate
2825
Back up light
7506
7506ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
7506LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Front sidemarker
2825
Rear sidemarker
2825
Glove box
3893
3893LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Map light
2825
Step/Courtesy light
2825
6418
6418LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Low beam headlamp
H1
High beam headlamp
H1
Parking light
2825
Front turn signal
7507
Rear turn signal
7507
Tail light
5007
7528
Stop light
7528
2825
H21W (64136)
Fog/Driving light
H1
License plate
2825
Back up light
7506
Front sidemarker
2825
Rear sidemarker
2825
Glove box
3893
Map light
2825
Step/Courtesy light
2825
6418
That's very surprising indeed. I'm looking to do the same thing front and back. No where I have seen says anything but the P21's. You've had her since new right? So, no chance the sockets/bulb holders got replaced?
If you ever get it done, could you post up a picture and give a first hand impression about the bulb quality and life span?
Yeah JagX, that info from the Sylvania site shows the same number for front and rear turn signals, as does my manual. The problem is that, on my car, the bulbs are not the same. The number listed works for the rear, but I have a different bulb in the front.
I ordered my car September of 2001 and it was custom built to get all the options exactly as I wanted. I took delivery of the car in December of 2001, so it was one of the very first X-Types. It appears that the later productions have the same bulbs front and rear.
I did install the Philips Silver Vision PY21W bulbs in the back and they do look great. No amber color when off and bright amber color when on.
bob, thanks that's a Jaguar number, but the question is... is it a different number than what they show for the rear?
Also, I don't think a parts store can convert a Jaguar number to their own. Plus, the Jag number would be for regular amber bulbs not "silver".
What I really need is probably a Sylvania or Philips number.
I was hoping someone else would have run into this so I could have the right bulb on hand before taking it apart again. Taking it apart for another look is plan B.
Plan C is to paint the existing bulbs. It's been done before, but it has it's own drawbacks.
Plan D is to just forget it... too much trouble.
I'm still working on solving the mystery on the front bulbs, but it may be a few more weeks before I really have the time to finish up. There are some other "silver" bulbs that look promising, but I still need to do some more research, ordering, install and pictures. I'll post the results when I get it all wrapped up.
Appreciate the info guys, Tiger wish I could help but I have no idea when it come's to things like this.. I wish you the best of luck and let us know what happens. Mohrd I'm in the same boat as you with the front end idea, I would probably do more hurt then good as well. Let's see what happens..
Sorry it took so long to get back to this thread, but I had a close encounter with a deer (not too serious) that set my schedule back a little.
Anyway, to answer the question I originally posted, the part number for the front turn signal bulbs on a very early X-Type is a Sylvania 3157.
Sylvania does make a silver coated bulb (SilverStar) which I ordered from Amazon. The coating on the SilverStar bulbs is more of an iridescent blue and amber color, which I didn't really like. So, I'm just leaving the original amber bulbs in until I can find a set of Philips Silver Vision bulbs for the front.
![](https://www.jaguarforums.com/forum/members/tiger88-48289-albums-forum-posts-1587-picture-3157-4340.jpg)
Edit: Note that these are not the bulbs used on most X-Types, don't order the 3157 bulbs unless you have actually looked at yours.
Shaguar Sextype (12-27-2010)
Guest
Posts: n/a
The right side cover's a snap to get on and off -- but that left one by the battery is a freakin' nightmare. Can't believe I got it on without having to remove anything else. Incredibly stupid design.
I know this is an old thread but I wanted to add that the front turn signals in my '05 are also this type of bulb. I'm not sure at what point they would have switched to the same bulb as the rear but I would assume from this info that at least '01-'05 use the 3157.
Also, looking on the sylvania site it says something along the lines of "bulb types vary, consult your manual" in reference to the front turn signal.
The one question I have is why they used a 3157 instead of a 3156. The 3157 is dual filament but doesn't our turn signal only light up at one intensity?
Going through this update on my XType as well. For the back tail lights how do you remove the bulb? Do you have to remove the 3 bolts and the housing or can you specifically remove just the turn signal light?
For the front headlight/ turn signal light. Any tips on getting this bulb out? I see on the US driver's side it looks like I am going to have to take the battery and battery housing off to get more room to work. Passenger side looks even worse.
Any help would be appreciated.
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
