Passenger Dashboard Rattle HELP
Old 06-05-2013, 07:48 AM
tarheel72's Avatar
David I was not trying to be a smart ***. Maybe your situation is different from mine. In my case the vents do have some small plastic tabs that hook under the lip of the dash, if I remember correctly. When the plug is seated the pressure and position of the vent keep it in place and it does not rattle. My plug, for some reason, had lost its stiffness and when it was plugged in it did not maintain the tension necessary to keep enough pressure on the vent cover to keep the tabs tightly pressed against the edge and the whole thing would rattle. The plug looked OK but the prongs were not holding tight enough.
Once I got a new plug and popped it in, the unit stayed tight and did not pop loose anymore. I think maybe heat caused the plug to weaken, but don't know that for sure. But the vent on the other side has had no problems so maybe that is not it at all. Regardless, I did not want to put any glue up there if I could avoid it, in case I ever had to remove the vent at a later date. If you feel differectly, then fine. Whatever works for you.
I don't mind the minimum wage but I just don't want the company.
Old 06-06-2013, 04:17 AM
David Lawrence Banks's Avatar
Default Ok
Hi yes ok apology accepted you weren't being a smart ****. Maybe the vent retaining system is different on later/earlier models. My vents have no inner retaining clips at all? I see many other people have experienced the same thing. Why would you want to remove the windscreen vents in the future? I mean I worked in Volvo main dealers for 25 years and only replaced two screen vents due to little children putting chocolate bars down the vents which jammed up the heater fan motor! don't ya just love kids. Have a nice Jaguar day : ))
Old 06-10-2013, 12:59 PM
JDBarrister's Avatar
Ihad a rattle I had to go hunting for and it turned out to be the garage dooropener buttons in the roof console. They were rattling around in their places.I happened to have a foil gum wrapper at the time and folded it in place tocushion the center button and my rattle went away. Someday I’ll do a morepermanent solution, but the gum wrapper has kept the rattle at bay for 6 monthsnow.
redxk8
10-04-2015 08:28 AM
inactualis
10-02-2015 11:13 AM
Lawrence
XJ40 ( XJ81 )
10-01-2015 08:36 AM
JagBrian
10-01-2015 12:52 AM
millertic
09-30-2015 08:11 PM
Quick Reply: Passenger Dashboard Rattle HELP
