Passenger side door locks
I have a 2002 X-Type Automatic with 61000 miles on it.
I just purchased it in December 2006. Any way, when I lock and unlock the doors, the passenger side front and rear doors do not lock and unlock. The alarm will arm, and if I open the passenger side front or rear door, the alarm will sound.
When I press the lock on the key, the drivers side front and rear doors will lock, but not the passenger side front and rear doors. I have to manually lock and unlock the passenger side front and rear doors from the inside of the car.
Anyone know what might be the problem?
Guest
Posts: n/a
listen carefully inside the door... do you hear any noise when you lock it?
there are not so many possibilities.. I think there is one fuse for all 4 doors so not likely that.
I think the door panels have to come off .. check if the linkage etc.. is OK and then check if there is power going to the door lock actuators. may be 2 disconnected linkages. or dead actuators.
does not sound like it will be a free fix... have you asked the dealer if they are covered under warranty? that may be the only easy hope.. when does or did the 4 year warranty expire?
When I click the lock/unlock button on the keyfob, I do not hear anything at the passenger side front and rear doors. When I manually unlock and lock either passenger side front and rear door from the inside of the car, the drivers side doors lock and unlock as well. However, if I manually lock either the passenger side front or rear door, the other passenger side door does not lock or unlock, yet there is a sound like the driver side locks are responding.
Any ideas, folks?
Regarding the linkages, are they connected to the actuators and push and pull the device that activate the locks?
Is there a write up on removing and replacing the actuators?
Is there an after market supply house where I can purchase replacement actuators?
Thanks in advance
Any ideas, folks?
Thanks in advance
You have brought up a post that is over 11 years ago. It would be best if you posted your problem and what is happening in a new post in the X100 forum. There the members can help you out. You say you have the same problem. Give a little more info in your post and we can see what we can do.
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
Dicque
09-19-2015 12:53 PM
