Passenger side wing mirror replacement
You can remove the glass. BUT Be very careful of the center adjustment. There is plastic tabs that can easily break dead center of the mirror. Best thing is if the mirror is cracked pull from both edges while holding your thumbs in the center of the mirror.
Hope this Helps,
Good Luck,
The Dr!
Hope this Helps,
Good Luck,
The Dr!
The following 2 users liked this post by Dr dome:
NotTheLotion (03-14-2014),
X2004 (02-05-2014)
You can get one for $53 at Genuine Jaguar Parts Online at Discount - Jaguar Replacement Auto Parts. I've just received mine.
NotTheLotion (03-07-2014)
Here is the procedure:
http://www.mediafire.com/view/?j2ad10w101ln5pl
I found it on another post but have not performed it yet.
What did you look under to find it?
Ok great thank you!!! I will try it as soon as I can find another one.
I haven't done mine yet, as it is still too cold up here. Instead, I have to deal with a chip on my windshield from a small rock that hit me yesterday Fortunately, I booked a mobile repair service through the internet and they're coming today to fix it while it's still manageable.
I'm sure you will succeed. If you could make a video of the replacement it would be great. There are a few on YouTube.
LOL! I just had the same rock incident happen yesterday and had it repaired. Small world Anyway, I just got done with the removal and installation. It literally took me like 3 minutes-including cleaning off the finger prints. Installing it warrants a gentle took on the outer edge. You have to put slight pressure on the inside edge while trying to snap back on the outside edge. You need to put your 4 fingers on the backside of the motors side clip WHILE using your thumb to push on the mirror to snap it back on. The reason I say use your fingers like this instead of just pushing on the outer edge is because the mirror may crack since you are pushing on the inner side at the same time. Does this make since?? Hope this helps someone else like others have helped me above
If anyone would like me to make a video of this, I will be more than happy to. Just let me know.
At last,mirror successfully replaced!
The removal was easier than the install; I had to "play" a lot with it before it "clicked" into its spot. Altogether, it took 5 minutes. You have to insert the portion closest to the car first and then "push in" the portion farthest from the car.
Unfortunately, there was nobody available to video me doing it, but there are a few videos on YouTube showing how with other car makes.
Confused (08-01-2015)
Jaguar wanted 1850 to repair mirror and motors. I got new motor and mirror because mirror mounts broke out with mirror and trim cap when it got hit.
I bought them myself and installed it but didn't know how to snap it in until I found this thread. Then it took about one minute. thanks so much. Also only cost about 350.
YIKES! $350. I know its too late to say but there were whole side mirror assemblies on Ebay that cost $99. I guess for future reference....
Glad it was successful for you! I love it when a plan comes together
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
