pecus error e
Received 4,285 Likes
I've moved your post to the appropriate X-Type model forum for better response. As JagV8 mentioned - you can use the search feature to locate info. As this is your first post, please take a moment to stop by the New Member section and post an intro. In return, you'll receive a warm welcome and useful tips to navigate the forum.
https://www.jaguarforums.com/forum/n...-intro-must-5/
JagV8 (11-21-2018)
Pecus stands for = "Programmable Electronics Controls Units System"
The suffix e means ECU
Most common causes are:
1. Failing or dead battery (low voltage)
2. Battery leads corrosion and not connecting properly (again low voltage)
3. Water intrusion into the ECU
4. ECU failure
Here is a link to a test (pin out) to check things =
https://www.justanswer.com/jaguar/7y...type-2-5l.html
4. ECU failure
sklimii (11-21-2018)
