Pecus Error E (Jaguar X Type - 2003)
Welcome to the forum professor2hu,
I've moved your question from Other Jaguar Models / Concepts / Replicas to X-Type forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post A NEW THREAD with some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
professor2hu (01-03-2014)
I've run a forum search to see if we have anything on this error. The only thread I can turn up is this one:
https://www.jaguarforums.com/forum/x...e-3-0-a-45130/
If it's as simple as a discharged/failing battery then count yourself as very lucky! Certainly worth checking and eliminating this before assuming anything worse.
Other resources are low on information but suggest 'PECUS error' is a programming error and the 'E' indicates it is the ECM (Engine Control Module). This is likely to be a dealer fix or an Indy with dealer level diagnostics.
Hello. I have solution for PECUS ERROR E on ecu denso. I try do it on jaguar x-type 2003 2.5. All work fine.
Info for you.
