PIC Small amount of oil on garage floor...
This morning as I pulled out of the garage I noticed a small puddle of oil. It was not a round spot but instead long as if wind from traveling caused the oil torun towards the back of the car. After inspecting the car underneath everything seemed dry - engine oil level was fine. As I arrived at work I took a look after the car was parked for 20 minutes and no oil leak.
The area on the garage floor that corresponds with where theleak came fromwould bethe front drivers side half of the car. Is there anything there that could possible leak oil?
Many moons ago I had a nieghbor in Maryland whom we are still friends with. I spoke with his wife if I could go into thier garage and
drop some oil under his car ( he had epoxyed the floor so no damage). His wife loved the idea.
This went on for 2 months and driving him absolutly crazy. Check your nieghbors.
Well I was under the car last night and it seems the leak or spill was confined to that area. The power steering fluid was fine. It was at the 2nd indent on the dip stick. Engine oil is at a decent level. This is a really strange thing.
have you ever seen trading places - the quart of blood technique - maybe i did the quart of oil technique?
It doesnt appear to be leaking anymore this morning. The frame seems to be dry so I dont see any run off?
No, the mounts are solid, not oil filled, struts can leak, but not behind engine. Did you have a recent oil change? Maybe spilled some oil during oil change.
Like I said, hose off and recheck....
Check your brake fluid
Power steering fluid
And oil.
If it's not leaking maybe something weird happened. I wouldn't sweat it then.
And oil.
The car is still dry - all fluid levels are fine again - checked them last night after sitting all weekend.
The only thing I can think of, is, I just changed my headligh lens out and the car was jacked on and placed on jack stands while I was under removing the bumber cover. Maybe there was some oil sitting somewhere? But the oil appeared the following day... I'll keep an eye on it.
I think the TC has an overflow port /hole on top somehwere..When you had it jack up to one side you may have caused some lube to spill out of the TC case...I don't know this for sure...I seem to remember Bo or someone mentioning that before about the overflow hole....
Anyways, I'm out of ideas..
![](http://www.hummeraddicts.com/Smileys/Lots_O_Smileys/dontknow.gif)
Received 2,193 Likes
ORIGINAL: christo
Here is a picture of it - oil cant be leaking out of the bushing - can it lol?
![](http://www.christonet.com:81/oil.jpg)
How difficult of a job is as I would like to do it myself? Will the car need an alignment afterwards? Will I need any special tools?
I did use a hydrolic jack to lift the car and then sat it on jack stands. I had the whole front of the car in the air. I wonder if I broke this joint or was it something that was just old. The oil leaked out a few days later and was very dark in color.
