Pink Oily Fluid Leaking
The only pink ish fluids in an x type are the coolant, power steering fluid and if its an automatic then it can be transmission fluid. My power steering pump went on my which allowed the redish steering fluid to drip on floor on left side of car. I would check the coolant level to see if it is dropping and then check the power steering fluid level to see if that is dropping.
Good luck
Good luck
The control arms have s funky oil in them that can leak out. Happened to me. Cost me 600 bucks to replace.
Timmy Gibson
02-15-2016 11:46 PM
Timmy Gibson
02-12-2016 06:44 PM
sadepol01
02-11-2016 08:22 PM
jeff71
02-03-2016 07:41 AM
