Pleas tell me there's a trick to saving this control arm
I was having a hard time putting the ball joint in and the arm was stiff and when I was pushing down on the arm so that the ball joint could slip into the hub piece the bushing did that...now,
the ball joint went in and all I have to do is reinstall the brakes and I'm done....but I want to know if there's a trick to pushing it down or do I have to get a new arm?
If the ball joint post is in the hole you might get lucky with jacking it in like Dell said. My issue was it was **** eyed and therefore jacking would not correct. I had a heck of a time working it to get it to go. So much so, I re injured my tennis elbow and my arm has hurt for the las six weeks. I redid all 4 bearings.
On the onther hand, I have also done this with the greatest of ease like it was nearly effortless. I was amazed.
I tried lots of pry bars but the angles and slope of the control arm and sub-frame makes this terrible to do. What I found that worked for me is a 36" pipe wrench opened up wide to put the jaws almost sideways to the contol arm to allow for lots of leverage to move the control arm down compressing the bushing. I think I ended up with one leg/knee on the pipe wrench and both hands manipulating the upper arm on and over the ball joint post. If that makes any sense.
Good luck
Good luck
car5car
02-07-2019 01:02 PM
