Plenum Gasket Set for Lincoln LS
Old 07-03-2017, 03:41 PM
Spikepaga's Avatar
Default Plenum Gasket Set for Lincoln LS
Hey guys- sorry for all the topics- just trying to get my new to me X type in order- I am doing a couple of 6 hour trips in the next months and want to make sure everything is taken care of.
Although the car has 50k miles, it is 12 years old. Probably a good idea to swap the spark plugs. I bought a plenum gasket set for a Lincoln LS....I think this will work, but not too sure. Seemed like a good price for a set of six. They look identical on the pictures. Anyone know if they fit? Not a big loss at 6 for 20 bucks.
Old 07-04-2017, 06:52 AM
innzane's Avatar
Not sure here. The Lincoln has a plastic intake and we have a cast metal. The size should be the same, thickness or depth may differ. Let us know if she runs after.
Old 07-04-2017, 07:14 AM
Thermo's Avatar
Received 3,929 Likes on 3,225 Posts
Spike, yes, the gasket kit will work. If you run through the search feature here, I have the part numbers for the LS gaskets listed here so you can confirm the part number. I have both the upper and lowers with the associated FelPro numbers.
Old 07-04-2017, 08:59 AM
Spikepaga's Avatar
Hi Chris-
Tried searching the Motorcraft/Ford part number with no luck. I went ahead and bought the Motorcraft Lincoln LS set and also a set of Fel-Pro's just in case, I can always sell or return the Fel Pro set
Old 07-05-2017, 01:11 PM
wa3ra's Avatar
The last Fel-pro set I got had the IMT gaskets as well!
