Popping airvents - front side markers
So popping airvents is self explanitory, how can i fix this, should i just hot glue these back in, or use apoxy. And my front side marker keep popping out when i travel at high speeds, i know they have clips and stuff to hold them in but they are NOT working. Can i glue these too, i know it will be a hassle to get them out in the event of changing a light bulb.
Disco my boy, put the epoxy down and slowly back away. Epoxy is mean as a "forever" adhesive.
The vents, even with the "improved" style, can and will still pop up. Take a tiny drop of Gorilla glue (or something like that) and put it on the tip of the plastic button fastener that holds the vent down. That is all you need to do to fix that problem.
The side markers can be a pain in the butt. Are you pushing them back (toward the rear of the car) with a good amount of force? If you are seating them and they still pop out, perhaps a tiny bit of rubber cement would help hold them in place, but not be impossible to remove. A little clear silicone caulk could also be used. Use sparingly.
