Positive battery cable
Ok, so I'm very new to all this, hope it goes through. I bought a 2003 x type. The battery light came on. Read as many Post's adi could and found out that my cables could be bad. Once i looked at cables the Post's were terribly corroded, I cleaned them, still have an occasional light. So I was going to change the cables, but before I did, i noticed a small cable that's connected to the positive wire that goes to fuse box that's not pluged in anywhere. Should it be? If so where? Thanks
I've moved your question from General Tech Help to X-Type forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Thanks Avern1 for replying. Here is a photo of what I'm looking at. The cable my finger are under is the positive cable that runs from fuse box to battery. The plug on the smaller wire was just laying under fuse box. Moved it for pic. .any ideas?
I also noticed that the positive cable going to the solenoid is also connected to the cable going to the alternator with one cable end. In other words, to cange the cable, it looks as the i have to unhook it from alternator. Is this a jag thing, or did someone make the cable this way.?
Thanks Bud, I'm gonna go ahead and change them both, but i did notice that on the solenoid the cable was loose, in other i could move it up & down, I'm thinking this might have caused a lot of my problems. It wasn't making good connection. Although it has always started.
