power distribution ratio?
Guest
Posts: n/a
My understanding is that the rear gets more torque than the front. I have not counted the gear teeth nor measured the diameters of the planetary gearset, but I assume the split is around 60% rear. I have not read any weight distribution data, I dont think that 60% is in the front tho. that sounds high.
BMW tries to get all its cars weight balanced 50:50. Their awd transfer case gives more torque to the rear to give the car a rear wheel drive feel. It also makes sense that when you accelerate, the weight changes and more weight is on the rear wheels.
Also of significance is that 02 and o3 x types have a viscous coupling in the tranfer case to limit slip front to rear. the newer cars, and any with a rebuilt TC will not have the VC.
I find that hard to believe..Without a Viscous Coupling..I would think that the drive ratio would have to be 50:50..Otherwise some gears are going to get grounded off in a hurry..Simple mechanics would demonstrate you can't have the fronts turning at a 40 turns rate fixed,as the rears turn at a 60 turn rate without some sort of slippage..ergo; VC..
Guest
Posts: n/a
ORIGINAL: Dennis
The rear tires will spin on occasion... at "random" when you give it a little gas during a turn ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Thats on an 02 though..
40/60
39/61..
same thing!
on 02-03 there is 40% power to the front and 60% to the rear
reading this post though you guys have me confused as hell!
And weight should be 50/50.. they even took the spare tire into consideration.
Which is why I feel like a dumbass sometimes because I think it handles better without it.
lol
40/60
39/61..
same thing!
lol
Yeah 60/40 or 61/39 is more or less the same I was just being more exact with the normal torque split.
Read this as the figure comes from just obver 1/2 way down the page:-
http://jagmotorproject.blogspot.com/...sfer-time.html
Guest
Posts: n/a
ORIGINAL: BuckMR2
good write up, and helpful pics, I would like to propose that there are 2 fairly large errors on this.
Firstly the drain plug does not drain 550ml. It drains about 400ml.
Secondly, The description of the planetary gear set is not correct, the concentric shafts shafts do not turn at different speeds when the car is driving in a straight line.
derek15301xjr
10-20-2015 07:39 PM
