Power Steering Fluid
![Post](https://www.jaguarforums.com/forum/images/icons/icon1.gif)
Hi,
Since I havenīt found any exact/accurate answer about this topic I decided to start my "own", the car is now transitioning from the 56.000 miles forward to the next 10.000 leap and considering this and the fact that I think the Power steering fluid has never being changed since new (2007) I think it would be recommended to do so right?
So the next question would be what should I change it to and whatīs the most accurate if not equal OEM fluid Jag putīs in this cars and what characteristics should it have?
Also whatīs the most easy/fast/reliable method to do this job?
Thank you,
John
Thank you,
John
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
I like the guy in this video who is a Ford tech but this technique might apply to our xtypes... He does a lot of helpful videos on various Ford car issues.
How To Perform a Power Steeering Flush On Your Ford At Home! - YouTube
Regarding the fluid I think is best to check the owners manual since you there are at least 3 types of fluid, I find best to use the "internet popular american turkey baster method" since I do think that if you donīt let the fluid reach low or the reservoir to empty you can get away without have to bleed the system.
I will need somebody to confirm this theory though that you can "clean" the whole system by using this method.
Thank you,
John
The video method is the best way. I use this same method with automatic transmissions using the cooling lines. I do use a measured bucket to make sure I put back what I take out knowing the system capacity.
That said, if you are just doing this as a general service, the turkey baster way should be fine. I would make sure you do a 150% to 200% change in fluids as you are mixing some new with some old each time. I would do it once a week for a month. I will do mine come spring.
chatmanx
01-13-2016 02:22 PM
theshortwhiteguy
01-10-2016 05:29 PM
