Hello all,
Let me begin by saying I have used this site many times troubleshooting issues in the past but never registered and this forum has saved me immensely.
Now to topic. I am trying to figure out what wires do what job. If there is a wiring schematic anywhere that would be great. I have tried google everywhere and cannot come up with anything. (I need master switch wiring as well as passenger switches.)
Thank you in advance
Jessie
JLC, keep in mind that the wiring for power windows serves a dual purpose because the window runs in 2 directions (ie, the ground wire for the window going up is the power wire for going down). If you PM me your e-mail address, I will send you a copy of the wiring diagrams for your car in PDF format. I just need to know what year car you have so I send you the correct drawings (minor changes were made in mid 2004). If you have a 2004 car, inside the driver's door jam is the build date, I will need that too since there are 2 different diagrams for the 2004 model.
Thermo, I am not quite sure if i can PM yet due to my post count. Either that or this forum is set up different from other car forum sites I use.
However my car is 2002 X-Type 2.5L AWD automatic. "Premium package" It has door tweeters in all 4 doors and premium sound box in top of trunk/boot and disc changer in trunk/boot as well. (not sure if any of those options make a difference).
JLC, if you download the repair manual from the link above, that should have all the info that you need. If not, get a few more posts under your belt and then the PM ability should open up for you.
what about stype V6 2001 gauge of those window motor wires?
JaguarJackson, are you asking for a wiring diagram for your 2001 S-Type? I am not getting what you are asking for. If you need a wiring diagram, PM me your e-mail addy and I will send it your way.
