Probelm with Sunroof
Hi All,
Recently i have the following problem with the Sunroof of my 2001 X-type:
When I press the Sunrooft button with the back arrow, the Sunroof does not perform any action. While when i press the Sunroof button with the front arrow, the Sunroof does open, but i have to hold the button until the Sunroof open/close completely.
The button with back arrow should open/close the Sunroof completely with one press.
Anyone know where was the problem, and which parts i have to replace?
Many thanks
Many thanks
I had this same problem on mine. I followed the steps here,
https://www.jaguarforums.com/forum/s...ead.php?t=5777
It should be post # 4.
Hope this helps.
Hope this helps.
The back arrow on my sunrrof does not work at all. The front arrow works, but it wont close the sunroof unless I do the 20 second reset (holding the front button for 20 seconds with the roof tilted open, then releaseing and pressing again to run through its segemt). Then it will close. I have to do this every time I want to seal the sunroof. Any ideas?
Received 3,922 Likes
