Programming Transponder Fob (must have 2 working keys first)
Old 06-17-2017 | 05:57 PM
Dell Gailey's Avatar
Post Programming Transponder Fob (must have 2 working keys first)
https://www.jaguarforums.com/forum/x...ed-know-87749/
So according to this post, additional keys after first 2 currently working ones, can be programmed without Mongoose cable and SDD software.
Old 06-17-2017 | 09:31 PM
motorcarman's Avatar
Correct, BUT........................
The keys need to be configured to the car as original keys and NOT configured using the 'two-key' method.
You cannot configure a key (#3) and use THAT KEY to configure another (#4).
The KTM system will recognize up to 5 keys. You must always use 1 & 2 to configure subsequent keys (#3 to #5).
As stated in the document "Upper portion of Key Fob Programming of transponder to the cars ignition to be able to start the car.Must have the two original keys. If one is missing will have to reprogram all keys using Dealer WDS/SDD software."
bob
Old 06-18-2017 | 03:36 AM
daddylogan's Avatar
Basically Original Key 1 and Original Key 2 MUST be present in the procedure in order to program Key #03, Key #04 and key #05. Makes perfect sense and keeps it secure.
I wonder how you know if you have original keys? I would suspect everybody has at least one of them and the lucky ones got 2!!!!
peace out,
daddylogan
Old 06-18-2017 | 07:30 AM
JagXSE's Avatar
Exclamation X Type diy key programming
For forum members file.
File Type: pdf
Old 06-18-2017 | 10:58 AM
We were issued that TSB for KEYFOB TRANSMITTERS after the replacement of the GECM during a RECALL. (Jaguar did NOT want to pay us for .3 Diagnostic Time as well as .1 Drive-in-Drive-out.)
The OP was wanting info on TRANSPONDERS.
bob
