Programming your own key for X-Type?
I am new to Jaguar as well as this forum, I just purchased my first x-type and both the key fabs do not activate the car with fresh batteries. Is it possible to program your own keys with a programmer available online? Is there a specific brand that is widely used by the home mechanic? I called to have the keys re programmed at a Jag shop and the cost is over $200, the cost of some programmers.
Foxwell NT510 Multi-System Scanner for Land Rover and Jaguar with Advanced Functions Such As Actuation, Adaptation And Programming https://www.amazon.ca/dp/B014CT4WU8/..._qYufybVBAV6NJ
Received 3,887 Likes
James, if you are only programming the push button on the fob, then all that you should need is a good key that can start the car. From there, you follow the standard fob programming and you should be able to mate up a new fob portion of the key without any programming tools needed. If you were trying to program a new key, you could need the specialized software. But, since you mention that you have 2 good keys that start the car, again, no software needed.
I am confused about you problem. The keys are TWO PARTS. The key blade and the keyfob transmitter. They are both snapped together but are completely separate components. Do you need KEYS (transponders) or KEYFOB TRANSMITTERS configured to your car????????
more info please.
There is a vast amount of info on this forum. TSBs are your friend.
bob
more info please.
bob
PanamaJag (11-01-2016)
1 Post
JOhnny, the program that you would need to program the keys is called SSD. If you look on e-bay, you can buy it there, but plan on spending about $500+ to get the laptop/program. There are knock-off programs out there that you can download, but you need to be careful what you get as some may have viruses in them, some versions require you to subscribe to the Jaguar Technician site (costs a few hundred USD a year as I recall to have a subscription) and some are fairly old versions (which in your case may not be such a bad thing). Not to mention that you would also need to buy what is called a Mongoose cable. The Mongoose cable has the OBD port on one end and a USB plug on the other. This is what allows you to take your laptop and talk with the car. Once you can run SSD, then you can get into the key programming section and do what you need. I have not played with SSD personally, but seen a few discussions here on the subject.
This is where a tow and paying a dealership to program the keys may be the cheaper way. Depending on the size of town you live in, you may be able to find a local locksmith that works on cars and they may have the software. But the locksmith is going to be a hit and miss sort of thing and will probably require you to call numerous shops before you find one that can do what you need.
You can get good virtual machines running sdd here https://drive.google.com/drive/folde...WZu0WPnOcUqwEJ You need virtual box installed to run them. You will also need a Mongoose cable or decent clone to link to the car. The images have worked fine for me.
Bruce in North Dakota (12-25-2019)
