prop shaft question
prop shaft question
I have a 02 x type and I have greased the "prop shaft carrier bearing" in the past but its time to replace it/them. I have the access to a lift and press and read the post with part numbers by member "cujet" who has a 03 x type. My question is will my 02 x type take the same bearings as his 03? If not what are these bearings actually called or found under in a jaguar parts lookup so that I can find a parts diagram or number for them? Any help would be appreciated. Thanks
James007
09-06-2015 06:47 PM
innzane
09-02-2015 10:08 AM
