pulled some codes... need some help...
Pulled the following codes:
P0171 System too lean / bank 1
P0174 System too lean / bank 2
P1111 Manufacturer control fuel air metering
P1000 fuel air metering aux emissions controls
Not sure what these are point to... but any suggestions would be great.
Thanks,
Andy
Thanks,
Andy
Might just be one problem if all 3 codes were logged at the same time.Sometimes a leak in a pipe or seal can cause other sensors further downstream to log faults.Check the thread on how to remove and refit the cranckcase breather hose which is a common failure and hence the newer sturdier pipe for a £5 in under 2 mins
Looks like i got it fixed. At least the engine light is out and the car seems to be running much better (no rough idle at start up).
The hose going from the PCV to the intake manifold / it runs right along side the throtle body, was split right down the middle. I tried to fix it once before by sealing it with electric tape and it worked at the time because the split was very small. I guess the hose was really a piece of crap because the split was almost the entire length of the hose now.
Anywayz.... $1.59 for a piece of new hose and all is well.
Lets hope the codes dont come back.
Glad its sorted
LnrB
09-24-2015 11:16 AM
