Push button start
Received 3,887 Likes
Ace, the question is really to what degree of function are you wanting this pushbutton to perform. If you want simply something to engage the starter motor and that is it, then that is very, very simple. If you are after something like what MB has in their cars where you just sit in the seat, push the button and everything else happens automatically, then you are talking about an expensive upgrade.
So, to what level are you imagining? Anything is possible if you are willing to spend enough money.
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
![Icon Snowman](https://www.jaguarforums.com/forum/images/smilies/icon_snowman.gif)
Jaguar and my local mechanic recommend not to do this type of mod. Jaguar flat out refused saying it screw up the electronics in the key FOB and the alarm wiring, My mechanic, say the say thing as someone posted WHY? just to be cool is not a good reason to take on a project like this. Older cars that did not have a lot of electronic tied into the key fob, it would be very easy to wire, but today, unless your car comes with a push-button start it would be very difficult to do even with a wire diagram. Also, both Jag and my mechanic said you would still need to turn on the key so the button would work, it probably can to be wired like a modern car which you only need to the the key FOB on your person to push-button the start.![Icon Snowman](https://www.jaguarforums.com/forum/images/smilies/icon_snowman.gif)
I had one on my old track car because A) it was made by Weld Techniques and was super rare and cool and B) it acted as a kill switch which you need to have on the track.
![](https://img163.imageshack.us/img163/7254/le348d6c1320028d59ff38f.jpg)
Way back in the 60's I had a 59 MGA with push button start standed equipment. Also, in 64 or 65, I forget it been so long I bought a brand new Austin Healy 300 MK11 and it also had push button start. Both cars had keys as you had to turn on the electrics so the car would start and the key was also there so no one else but U can drive away with it. Today's cars with push button all you need is the FOB on your person and it will start. Tech and time go marching on.
the bar method is the trademarked name of an exercise program that is marketed by The Bar Method, Inc.
