question about winter rims
check out the link below & you ill get the answer
http://www.discountedwheelwarehouse...._Reference.cfm
I ordered mine from Tirerack.com last year. I went with the Dunlop SP Winter Sport 3D and MSW wheels.
http://www.tirerack.com/wheels/MiniW...ackage&sw=1120
Downsized my 18's to 16's for better snow traction. Worked like a charm! Dedicated snow tires meant I could actually drive through real snow as opposed to the summer tires which got stuck in anything more than 1". Low cost wheel for winter use. Also bought my 18" OZ Canyon II from them when they were cheaper.
In case the link above doesn't work they are:
MSW Type 14
• Size: 16x7, 48mm Offset
• Price: $94 (each)
• Est. Availability: In Stock
• Weight: 18.0lbs.
• Finish: Silver Painted
• Bolt Pattern: 5-108
• Construction: 1 Pc. Gravity Cast
MSW Type 14
• Price: $94 (each)
• Weight: 18.0lbs.
Let me see if this works....
My 16" winter setup...
And my 18" summer setup...
http://www.tirerack.com/wheels/MiniW...d=true&sw=1120
lickahotskillet
10-18-2015 09:51 AM
James007
09-06-2015 06:47 PM
