Questions about x-type options
If you haven't read my thread in New Members section, I'm looking for an x-type and I have a couple questions about options.
My budget only allows for a 2002-2004 models, and I really want the green gauge faces. If I buy one without them, how hard is it to get some green ones?
Was heated leather seats an option for those years?
And I have a picture of an interior I will have to upload later with some questions.
TIA
TIA
Received 3,901 Likes
bigcat318, from the looks of things, there is only 1 change that has been made to the interior that you show. That would be the steering wheel should be more of a brown vice the all black that is in the picture. As for making that happen, this is about $100 and about an hour of your time. All that you would need to do is to disconnect the battery (VERY!!!!!! IMPORTANT!!!!!!), wait about 5 minutes to let any residual voltage bleed off, remove the air bag (2 screws on the backside as I recall), undo the nut in the center of the steering wheel, and then undo the plugs for the steering wheel. From there, you get a steering wheel puller and pop the old steering wheel off. From there, you install the new steering wheel, tighten the nut down. Install the new airbag (will need to be the black faced one like what is in the picture vice the brown that the car came with) and then reconnect the battery.
On a side note, when you remove the airbag, for safety concerns, pull the airbag from the steering wheel and then immediately point it away from you before pulling the plug. That way, if the airbag for some unknown reason decides to deploy, it will do so away from you. Along those same lines, once the airbag is removed from the vehicle, place it on the ground with the side that normally faces you up. that way, should it deploy, it only puffs up, not get launched across the yard.
The setup in the picture is the same in my 02 Sport Premium.
Trim Color Dove
Perforated Steering Wheel
Warm Charcoal / Dove Fascia
Nimbus Grey Headlining
Flint Grey Carpet
Birds Eye Maple Grey Veneer
On the equipment list features
Options that is part of the premium package
Garage door opener
AutoDim Interior Mirror
Heated Front Seats 2 stage
Premium Sound
Reverse Park Control
Headlamp Power Wash
Rain Sensing Wipers
Bi Xenon Headlights
I wish though mine have the navigation. I'm buying stuff at ebay & hopefully & successfully someday to install the navigation. & Rear seat entertainment.
Trim Color Dove
Flint Grey Carpet
Garage door opener
Premium Sound
Headlamp Power Wash
Rain Sensing Wipers
Bi Xenon Headlights
bigcat318 (11-05-2011)
bigcat318, I believe it will physically mount up. But, where you may have issues is getting the steering wheel buttons to work properly. This would mean pulling the pins out of the S-Type steering wheel, putting the X-Type plug on the end, matching up the wires to the correct spots inside of the plug, and then hoping that the switches on the S-Type wheel are the same resistance as the ones on the X-Type. I can find the values of the S-Type resistors, but the X-Type diagrams are mum on their values. So, it will be a hit and miss sort of thing. It may be possible that the switches are interchangeable, but I am not 100% sure on that.
What you are probably running into is that most sport models had black interior. Thats exactly the same problem I ran into while looking at what jag to buy
This is a list of things I want:
-light interior
-manual trans
-heated seats
-exterior: not red or blue
If I found one with manual trans, dark interior with heated seats, how hard would it be to change most of the interior light? Seats, console, door trim etc?
OR
If I found one with light interior and no heated seats, how hard is it to install heaters? With factory switches? This sounds like the cheapest/easiest option.
-light interior
-manual trans
-heated seats
OR
