R R window quirk
Not exactly a serious problem, but.....
The right rear window in my '03 X operates perfectly (as do the other 3) from either the r r seat control button, or the driver's seat control for same, but when I use the 'Global Locking' feature, the other windows, moon-roof, door locks all do their thing, but not the r r window. I have to turn the ignition on and power that window up with the button.
Any ideas?
Any ideas?
![Icon Violin](https://www.jaguarforums.com/forum/images/smilies/icon_violin.gif)
If you press to open the window then let go of the switch, does it continue or stop?
If it stops, press to open, hold the switch until open and hold for a further 5 seconds or until you hear a click, press and hold the switch to close the window, hold the switch for 5 seconds after it closes or until you hear a click.
Try global closing.
Try global closing.
Maybe it has to do with the door. When you try the global locking is the door itself locking where you can see the lock button on that door move, or does that stay open? If it stays open maybe that is what is preventing it. When I had my X I had the right rear passenger lock that seemed to stick at times (maybe because I didn't use it much). Maybe that is what is causing the window not to move.
labcoatguy
02-08-2016 09:44 PM
