Radiator drain plug
Received 3,908 Likes
Lotion, if you look in front of the passenger tire, you should see a square hole (about 3x4 as I recall from memory). If you reach up in there, you will feel the flat blade of the drain valve. Twist it counter clockwise and it will start draining. Just be ready with a few catch pans as you are going to have fluid leaking out a lot of spots on the front corner of the car. You can try parking the car on a slight hill with the front of the car facing down to try and control where the fluid goes. May even be helpful to put a jack under the driver's side to raise that side by an inch or so.
aholbro1
08-05-2021 05:02 AM
chatmanx
09-11-2015 07:17 PM
