Radiator Fan
Okie dokie,
So its time, I need to replace my fans, controller, and my back radiator, along with some other goodies. I will be taking my time with this as the Jag is my backup car that I take out on weekends. It will obviously sit while I do all this.
Here is what I am wanting to do.
No, I would prefer not to buy the upgraded factory module and fan set as its $1000 and a little cheaper on ebay or amazon. So what.
What I would prefer is an aftermarket setup so it can be more affordable. I was looking at this guy here.
I know what matters in the end....total airflow through the radiator so my question there lies in the fact of will this bad boy move enough air to keep things cool. If not, can you suggest one that will? This fan comes with a gauge, relay and controller. Suggestions are welcome I just want to avoid spending a grand to fix this seemingly easy issue.
Received 3,886 Likes
bracester, the rule that I have always used for vehicles is you need a minimum of 3000 cfm of air from the fan(s) on the vehicle. This one happens to provide 3300 cfm. So, you are good there.
I am sure you can make it work to keep the engine cool. That is a very simple thing to accomplish. Where I think you may have an issue is getting it to kick on when you are using the A/C system. HOpefully the controller that comes with the fan has a separate lead for the A/C system. Otherwise, you are going to have to come up with a second controller just for the A/C system. Otherwise, what you will experience is in slow driving (ie, under 30 mph) and when stopped, the A/C system will not cool the car adequately (especially where you live). Above 30 mph, the air flow through the fan is more than the fan can move since the car is moving through the air.
If you need more info, let me know. I did a conversion on my truck and that was some of the problems I ran into with my truck. The only other "problem" that I can see is the computer may throw a code as the ECM is what controls the fan on our cars and if it isn't seeing a load, it may see it as an issue.
bracester, most people tap into the wiring for the A/C clutch. Probably best to simply wire it in parallel to the clutch itself (ie, downstream of the over pressure switch). The load that the new controller is going to add is going to be minimal and will have no effect on the wiring or the overpressure switch for longevity. If you need me to go down to the wire color, let me know. I just don't have that info in front of me at the moment.
Im actually having a similar issue with my fans. The fan thats lower of the two, the one on the drivers side doesnt turn on. So I have to turn on the a/c on and manually put on a high fan speed. It still doesnt turn on that fan but the other fan cools off the interior and of coarse if Im driving then the cabin temp gets cold. Is there any way to get that drivers side fan to work? Im in the USA, just in case you would ask which side is the drivers side.
Any suggestions please?
The small fan that is on usa drivers side which is lower down never turns on;the one that does is the larger one clearly visible on passenger front side by the radiator.
Found out I just needed to tap the red wire on the AC clutch power wires. Got it all installed and its a tight fit just like stock, lesson learned to bend the four brackets to a slight curve for a more solid mounting to the radiator. Now just need to jump it to get it started and testing for functionality and leaks. Will report back.
JoshuaKM1
04-27-2019 04:04 AM
dvsadam
27
11-01-2015 12:32 PM
firstchoice
10-11-2015 08:15 PM
