Radiator fans
Old 07-31-2024, 12:50 AM
apb's Avatar
apb
apb is offline
Thanks Mark, I just learned about test pins that are available that do just that and I have a set coming. Hopefully I won't need them for the fan issue as I think the R5 relay replacement has cured the problem. They may be helpful in solving the alternator light especially if I can find a way to get a hand in behind the alternator to use them.
Old 07-31-2024, 03:40 AM
h2o2steam's Avatar
Received 1,989 Likes on 790 Posts
Don't want to sound like a broken record but you want to make sure you have eliminated the possibility of bad battery cables.
They can often deteriorate beneath the insulation where you can't see the problems.
Also bad earthing points are an issue that also keeps popping up for may reasons and faults.
The oddity is that where you have an earthing stud and multiple lugs going onto a stud, the order they are stacked on the stud seems to matter to the factory engineers.
Old 08-01-2024, 11:56 PM
apb's Avatar
apb
apb is offline
in post #21I said R5 but ment R7 I may have done that in other places so watch out. I don't see how to edit a post.
Fristim
08-09-2023 06:54 AM
Vadim
06-16-2023 06:25 PM
Doug Dooren
08-09-2015 01:30 PM
workoutman0011
04-05-2015 08:28 PM
Quick Reply: Radiator fans
