Radio Headunit Replaced...CDC function gone..Help
I replaced my OEM cassette radio unit to OEM cd player radio unit. All works well except for the CDC CD Changer. When I installed my OEM Cassette it recognizes it & works great. I got another OEM cd player radio unit & the same thing - no CDC function. Is there a setup to enable the CDC function?
I tried the search & couldn't find answer. So now the post. Thanks.
As Astro says, for non-Sat Nav it has to be enabled. However, when I did mine the main dealer said exactly the same to me as he has to you
Go to an independent (my guy is a Jag specialist and uses the aftermarket Autologic software). It took him less than 5 minutes, and I slung him $20 to do it.
Regards
Rob
Regards
Rob
While the independent was configuring the CDC, he also cleared another couple of errors that the car had captured.
Regards
Rob
Rockyf (08-09-2012)
BS. I was only charged for half an hour to enable the CDC, that's all the time it should take. This was before I retrofitted the SatNav which enables me to do it myself now.
Anyway, call another Jag dealer. Even if they want to charge you an hour, dealerships in the DC metro area charge $140, I bloody can't imagine Seattle dealers charging more. You'd still be better off finding an ind. shop.
