Radio Problems
Radio Problems
My 2002 x-type has sound only on the passenger side. When you access MODE and adjust L/R balance adding to left you get no sound and the volume on the right side decreases.
Is the problem in the head unit or the control unit. I am hoping some of the radio experts will chime in and help sort out.
Back in the "day" I would use a small 9 volt battery to test speakers and wiring. Put the (+) of the 9 volt battery to the (+) of the speaker wire. Put a wire on the (-) of the small 9 volt battery and use that wire to quickly tap on the (-) wire of the speaker. If all is good you will hear some static coming out of the speaker.
motorcarman (05-04-2016)
