Radio and rear de-frost
Received 3,929 Likes
You can get rid of the interference by adding a noise filter to the rear defroster wire. This will cut down the amount of oscillation in the voltage going to the rear defroster, which will reduce the interference that it is causing. You can pick up an noise filter at some car stereo stores or at places like Radio Shack. Wiring them up is pretty straight forward. Just need to make sure you get the correct wire for the rear defroster.
