Rear Axle CV Joint Nut Size or Interchange?
Received 12,932 Likes
Hi Joshua,
Welcome to the Jaguar Forums!
I have moved your post from the forum for the S-Type to the forum for the X-Type. Here you will find knowledgeable owners of similar cars.
Regarding the rear axle nuts, it is quite likely that the same size and type are used on other cars. If none of our members knows the correct size and type, it might be worth taking one of your old nuts to your local Ford dealer and asking if they carry a match.
It is important to note that, at least for the models I am familiar with, Jaguar states that the rear axle nuts must be used only once, and if removed for service, the old nut should be discarded and a new nut installed. I am aware of at least two Jaguar owners who reused the old nuts and had them come loose while driving their cars....
And since we're a friendly group, please visit the https://www.jaguarforums.com/forum/n...-intro-must-5/ and post an introduction so we can learn something about you and your Jag and give you a proper welcome.
Cheers,
Don
Cheers,
Don
al_roethlisberger
09-11-2015 10:04 PM
FS[SouthEast]: Rain X waterproof car cover NEW
Sublyminal
09-03-2015 04:48 PM
