rear caliper
![EEK!](https://www.jaguarforums.com/forum/images/smilies/eek.gif)
I did the brakes on the S last night, and that cube didn't fit the rear caliper. It was the first time that I did the brakes on the Jag, and the brakes were fine but the previous owner put the cheap **** on the car and they would squeak! Bendix Ceramic pads in the front now, and quiet like a mouse! They lock up real good too! I though that the rear was supposed to twist in, but I was twisting the rear caliper for like an hour and that **** went no where!
Received 9,008 Likes
Hey guys, I hope this helps because I had the same problem with the left rear caliper. the piston would not go back. I thought I would have to spend $700 for a new caliper, but I called a local jaguar dealer and they said for some reason this one is screwed back in -- COUNTER CLOCK WISE. I told my independant mechanic and sure enough it worked. I hope this helps you save some money!!
I'll try it tonight, but if it does screw in counter clockwise, I hope I didn't damage it by turning clockwise as long as I did. I spend at least 45 minutes turning that **** and it didn't come out at all! So if it doesn't come out, why would it go in if you turn it the other way? Either way, I'll let you guys know tomorrow after I change the rear brakes!
I'm glad that was helpful.
Anyone recommend a specific brake pad for their x-types. I heard alot about these ceramic brake pads such as better braking and more importantly no brake dust? are they worth it? and would you replace both the front and back brake pads with ceramic pads? thanks!
