Rear door speaker replacement
My rear speaker in the door is blown. I bought some replacement 6.5" pioneers that should work fine. My question is on how to remove the door panel. Seems like there's just one screw at the bottom to take out and then does the panel just pop upward/off????
Any info so I don't break any of the plastic holding it on would be mighty helpful.
Thanks.
Thanks.
There are 2 screws on the bottom, and one that hides behind a little cover behing the interior door handle.
There are numerous clips around the door. The only one i would be extremely concerned with ithe the one in the upper left (driver side) or upper right (passenger side). What happens here, if care is not taken, is the door panel itself breaks. You will need a panel tool to slide in there to remove the clip properly. The rest you can just pop off and replace as needed. At least that is what i did.
Should be interesting tho Lol.
similar on the back doors... but much harder.
also see my speaker repair link in this thread
https://www.jaguarforums.com/forum/s...ad.php?t=22729
i just added more pics on the back door pannels because i didnt put them in before.
hope this helps you, look at which parts you have to pull out stright, some push to the front and some pull to the back...
start at the bottom corner and work your way across the bottom, then go front and back
