Rear Driver's Side Squeak???
SO yesterday I took a short 2 hour trip to visit my grandma for her birthday. I decided to take the Jaguar to stretch her legs...Everything went fine until just about when I arrived home i started noticing this 'squeak'/ mattress spring noise coming from the drivers side rear tire area. For those of you that have lived or live in a city, you know the noise bad taxi cabs make when they go over bumps? its making that noise... I went underneath and tried lubing all the joints up to no avail. Any suggestions on a remedy and or what part needs to be replaced? This is on a 03' X-type Sport
Thanks Fella's
Thanks Fella's
My X makes the exact same squeak. I have narrowed it down to the pivot point for the rear suspension located in front of the driver side rear wheel, below the rear door. When I have someone else push down on the back corner of the car I can hear the noise coming from that pivot point.
That's as far as I've taken it, been too hot in the garage to start deeper investigations.
Yes I greased up the e-brake grommet on the underside of the car hoping that was the likely case but to no avail.
So far i've jacked the car up by the spring support and was able to still replicate the 'squeak' noise by lifting up on the wheel well arche of the car (dangerous I know)I've greased and lubed everything on that side of the car and the noise is still present.
Question though is if it is a bad sway bar link or something as mentioned in previous post's regarding this issue, where might one find parts for it or what places do you guys use to buy parts for your X-type?
I like my car i'm just not going to drive around town with that embarrassing squeak/ groan
I found all of the parts with a diagram breakdown at:
http://www.jaguarpartscenter.com/
I will be ordering a set to see if that takes care of the "squeaky mattress" sound.
Did a little more research, the part I am referring to is the trailing arm, and there are bushings in those.
I have ordered the trailing arm bushings and will spend a weekend on it soon, I am also replacing my ARB bushings with polyurethane universal equivalents while I'm under there.
In my car squeaking noise was coming from lower control arm bushings and when I sprayed some oil in it it stopped but another story is that I changed them and it was awful sight with them, http://gallery.photo.net/photo/11308373-lg.jpg
and now my Jag is totally different car to drive, the difference is huge!
99xk8guy
06-05-2023 06:28 AM
