Rear Hub & Bearing to Carrier Bolt Size
Good day all,
Just purchased two new rear hub & bearing assemblies for my 2003 X-Type, 2.5L gasoline Jag. Unfortunately, neither came with replacements bolts.
I've been able to determine that they are M10 X 30mm but I can't find the pitch of the bolt anywhere. Ie. M10 X 1.25 x 30mm?
Unfortunately the part number does not cross over here in Canada other than to say the bolt required is a M10x30mm.
If anyone knows the exact size, I would appreciate it if you could chime in.
Kind Regards
Kind Regards
Juliesjag69
01-04-2018 10:19 AM
jaysvw
04-06-2008 12:37 AM
rdcsat
11-16-2007 06:20 PM
