Rear parking module
Hi, really hoping for a little advice.
My rear parking sensor stopped working, although you can live without it it is nice to have it working. A local garage had a look at the sensors and wiring and in his opinion were ok and suggested replacing the module. The parking sensor prior just did not work, however, now I have replaced it it still doesn't work but now has a continuous warning when I turn the ignition on. This warning, with accompanying engine light warning, goes off after a few seconds. Does anyone know what I've done wrong?
You can start replacing all the components in the circuit until you get it fixed, OR you can read the module to see what circuit the module is faulting.
Some people will NOT take their car to a shop or dealer for diagnosis for any reason and will spend countless hours and replace countless parts until the problem is resolved.
The module already knows what circuit has a fault, but you need to ask the module!! (or throw parts at it until it works)
I have always been a diagnostician but I have worked with dozens of 'parts-changers' over the past 45 years. They get the car fixed but it costs the customer a bunch in parts in the long run!!
"Yes, there are two paths you can go by, but in the long run
There's still time to change the road you're on."
Jimmy Page/Robert Plant
gem
07-08-2011 01:44 PM
