Rear parking sensor removal
Hi John,
Welcome to the forum, if you have the time it will be useful to add your vehicle spec to your signature?
I hope this helps:
https://www.jaguarforums.com/forum/x...s-xtype-65116/
Ps, is that a Yamaha monicker you have... NICE JUST LIKE A JAG, I like bikes too!!! regards, Stu
I hope this helps:
This the right place for technical questions about your X-Type. I've removed your duplicate post from Jaguar Forums Advice / Feedback & Suggestion Center which is the place for posts about the forum.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
MT09 (04-08-2014)
Hi John,
I hope this helps:
I hope this helps:
Stuart Beattie (04-09-2014)
Received 3,928 Likes
MT09, I am one of those that broke a parking sensor. The best advice that I can tell you is to get your hands on 2 small flat bladed screw drivers (or something of similar shape). What you are going to do is to get under the car and locate the bad sensor. From there, you should see 2 tabs holding the sensor in place (about 180 degrees apart from one another). Use the screw drivers and get in under the tabs, using the screw drivers to hold the tabs out slightly. From there, get back to the outside of the car and using your thumb (or other suitable/soft pushing device, push the sensor into the center of the car. DO NOT!!!!! NEVER!!!!!!! twist the sensor. Doing so will almost garantee you will break the sensor.
If you have further questions, just ask.
Stuart Beattie (04-16-2014)
KarimPA
09-03-2015 07:32 PM
davidladewig
09-03-2015 06:32 PM
innzane
09-02-2015 10:08 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
