Rear parking sensors not working
Arvid, open up the hood/bonnet and look down behind the battery. You should be looking at the top of the transmission. Sticking out the top of the tranny will be 2 wires connected to a sensor. This is the reverse light switch. Disconnect the connector going to the switch and using a paperclip, stick it into the two openings in the connector. Do you reverse lights come on? If yes, you just proved that the switch is bad. Replace. If not, then some more troubleshooting will be required. It could be an issue between the fuse box and the switch or with the wiring between the switch and the rear of the car. This is where checking for 12 VDC on the paperclip will tell you which end of the car you are looking at having to troubleshoot. If you find 12 VDC on the paperclip, then the problem is in the rear of the car. No 12 VDC, it is between the connector and the engine bay fuse box. If you need to narrow things down more than that, let me know and I will tell you what needs to happen.
i am fairly new to this forum and i have been reading the thread my reverse lights work and when i put the car in reverse there is a clicking noise coming from all 4 sensors but it just doesnt work, Not when i turn the ignition on or if i put it in reverse its just dead no beeps nothing i checked the fuse (F79 on the passenger side fuse box ) this indicates both the reversing switch and the fuse is fine ps i just did the heads on my car could the mechanic not have connected somthing back after he stripped the heads to do a overhaul
i really am lost i think somthing maybe gone on the module in the boot any info would be appreciated
Kind regards
Justin
Received 3,909 Likes
Justinmoodley3 (08-11-2021)
Hi everyone, I didn't see if this question was answered but I have recently got an x type 2007 and noticed that the parking sensors aren’t working. Ive gone around the car listening to ‘chirping’ from the sensors and I have 2 located on the front that are not working. So my question is if that I have 2 front sensors not working does that mean that the rear sensors wont work either? Or does it not affect the rears sensors and there is another issue?
cheers in advance
cheers in advance
#30
#31
tech.advice
02-22-2017 09:17 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
