rear pass window stops at 3/4
02 sport. The rear pass window wont go down the last 3"-4". Is that the motor going bad, regulator or something else?
resolved: the magnet came off the factory speaker and was stuck to the door
My right, rear window will not go down "automatically." My mechanic tells me I need a new memory for my motor (?). So, are you holding down the button until it goes all the way down or are you experiencing my situation? Hope this helps. Thanks. New Member Bill in Wooster OH
This is what I did to fix it:
1) Fully close the window
2) Press and hold down the button until the window fully opens
3) Pull the button up and hold it until the window fully closes
4) Repeat step 2
5) Pull the button up once like you do when you want it to auto close, hold it for 3 seconds or so
6) Try using the auto close and it should work
Maybe something similar to this could fix your auto down feature
99xk8guy
06-05-2023 06:28 AM
