Rear Sway Bar Link
Received 3,887 Likes
Jonzy, looking at the JTIS, it looks like once you remove the nut off of the lower control arm, you should be able to slide the link down and out of the actual sway bar. IT may take a little bit of wiggling, but it should pop out for you. There are no fasteners holding it in. It may have a little bit of a friction clip holding it in place, so, a little bit of force may be needed.
The anti roll bar is threaded in the ends, and the link is screwed into the bar. You need to unscrew them. Take the whole bar off of the car, drill a radial hole through the link, put a tiny screwdriver, or something, through the hole and use that to unscrew, unless you manage with a pipe wrench (I didn't).
To get the link off of the rear lower arm, you need an allen key that goes at the threaded end of the link to keep it in place when undoing the nut.
When fitting the new links, put 3-4 washers before the nut to get som prestress in the bolt. Many jaguar owners experience a knocking noise from the rear suspension, I've located this noise often comes from the links nut coming loose just a tiny bit. More prestess in the joint will prevent the nut from coming loose.
When you have the bar off anyway, check the sliding stops next to the arb-bushings, they tend to rust and come off.
Good luck!
Good luck!
Hi,
You should check out the link below :
https://www.jaguarforums.com/forum/s...ad.php?t=22253
a Sway bar mystery
I've been hearing some knocking from the rear and ready to assume swaybar links. Got under there to discover I don't have a sway bar, driving me batty.
Attached is some pictures of what's not there. It's a 2001 Jaguar Vaden Plas. Std suspension. Any ideas? Maybe this model just didn't have it?
Holes are there.
I don't see any brackets to accommodate the sway bar though
Holes are there.
al_roethlisberger
05-25-2017 07:05 PM
