Rebuilding 3.0
Rebuilding 3.0
Finding conflicting answers on forums and google about what bolts on 3.0 v6 are ok to reuse and which are not (TTY bolts)
So far, I found following:
Head bolts, XR85387 not reusable
Camshaft Cap Bolt, XR851882 reusable
Connecting rod bolts, XR85342 not reusable. cheaper Ford part no. F3LY-6214-A (one set with four bolts)
Crankshaft Damper Bolt XR816493 not reusable
BEDPLATE BOLTS
Main Bearing Bolt M10 x 103mm XR83302 not reusable
Main Bearing Bolt M8 x 94mm XR85191 not reusable
Stud Bolt M8 x 94mm XR85193 not reusable
Bolt & Washer M8 x 75mm XR842250 reusable
Having problems finding Ford part numbers for duratec V6 (should be the same bolts as Jaguar?)
Would appreciate any info on this.
BEDPLATE BOLTS
Panthro (05-12-2019)
