AT RECALL exists and others. 02-03 X-type RECALL LIST.
RE: AT RECALL exists and others. 02-03 X-type RECALL LIST.
Campaign - Headlamp Power Wash Jet Link Replacement
XT501-S940
DATE 06/03
MODEL 2002-03 MY X-TYPE
VIN C00294-D29054
Headlamp Washer Jet Cover Pivot Link - Change Of Specification - Service Action S940
Issue:
On vehicles fitted with headlamp power wash, there has been a high incidence of headlamp washer jet cover loss; caused by the detachment of the link that attaches the jet telescope to the washer jet cover.
Action:
At the next available opportunity replace the link on all 2002-03 MY X-TYPE vehicles, within the above VIN range, that are equipped with headlamp power wash.Note: This Service Action covers the replacement of the link only. Should the headlamp washer jet covers be missing, please refer to Technical Bulletin: XT501-09. No claims for the headlamp washer jet covers will be covered under this Service Action
XT501-S940
DATE 06/03
VIN C00294-D29054
Issue:
Action:
Wipers/Washers - Headlamp Washer Jet Cover Falls Off
XT501-09
DATE 06/03
X-TYPE MODEL2002-03 MY X-TYPE
VIN C00001-D29054
Loss Of Headlamp Washer Jet Cover - Poor Retention - Install Pre-painted Covers/Revised Link
Issue:
Some 2002-03 MY X-TYPE vehicles within the above VIN range may experience the loss of one or both covers from the headlamp power wash jets.
Two new modified headlamp powerwash jet links and painted covers are to be installed, when one or both covers are missing.
Action:
On a customer complaint basis only, install all the components from the repair kit when one or both covers are missing.Note: Each kit includes two painted and modified covers and two modified links.
WORKSHOP PROCEDURE
1.Working on first headlamp powerwash jet, grip headlamp powerwash jet cover with fingers and slowly pull headlamp powerwash jet out to its operating position.
Note: If headlamp powerwash jet cover is missing/lost, pull headlamp powerwash jet slowly out to operating position using pliers or hook.
2.Displace and remove headlamp powerwash jet cover from link if installed.
3.Displace and remove headlamp powerwash jet cover link from headlamp powerwash jet (Illustration 1).
4.Install and seat new link to headlamp powerwash jet (Illustration 2).
Note: New link pegs are offset lowermost when installed for correct seating of cover to bumper.
5.Install new cover assembly to new link (Illustration 3).
Note: Powerwash jet covers are marked on the rear face left hand or right hand.
6.Slowly release headlamp powerwash jet to its retracted position.
7.Repeat steps 1 to 6 to install remaining headlamp powerwash jet link and cover.
XT501-09
DATE 06/03
VIN C00001-D29054
Issue:
Action:
WORKSHOP PROCEDURE
RE: A/T recall does exists and others. LIST.
Hi.
I have a 3.0 V6 X type with the Auto Transmission and have encountered a problem.
While driving i get a jolt as the car changes gear. Then when I get to about 60mph if i put my foot down the car revs excessively and wont sit back in gear. I then get the message flash up Gear box Fault. This wont go unless i stop and turn the car off for 5 mins or so then all seems fine. Mine is a 2002 can anyone offer advise?
My X type falls within the Vin number range for the Transmission replacement. However out of the near 30000 i am within the last 200. Does anyone know how long Jag will take to recall me and when this recall was issued.
Is there any way I can speed Jag up as I dont want to take mine in with the gearbox fault problem only for them to charge me?
Please help.
Please PM me with any info you may have.
Please help.
#30
ABS & ECM 02 xtype
I have a x type with vin that starts in the c.I am not original owner i do not have warenty,at this point my x type has abs broken .....and my car has been diagnose with"ECM FAILURE".Does anyone know if its possible that it needs only reconfiguration....as there might have been a recal for this.if not should i get both modules installed at same time.as it might be in the same place and save a couple hours of labor on it at the dealership.
#31
#32
I got a DDW printout from my dealer, and it appears my car may still have the original, recalled transmission - my VIN is C04916 and the Gearbox Number is 1377602 PL000. This is just slightly disconcerting, however I do have over 100,000 miles on my car, so I suspect in any case the recall would no longer be honored?
#33
Ruslan35,
Much thanks for posting these recalls.
If you wouldn't mind I would really appreciate the following 3 also:
XT310-S933030801Campaign - Fuel Tank Inspection/Replacement
XT303-S932030101Campaign - Cooling Fans Inoperative
XT418-S921020201Campaign - 20 Amp Micro Relay Bad Internal Connection
Jag_genius,
Did you hear a reason as to why they closed it?
Could they have possibly gone through all the questionable cars?
Jag_genius,
Just wondering how & why you are using my personal profile ????
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
