Removing Rust Question
The first think you want to do is just as The Chris X mentioned - protect the door paint with tape.
You might try using NEVER DULL for metal polishing (we use this to polish everything in the military). This stuff works miracles but it will attack paint in a heartbeat if not properly protected.
I see you've mentioned some other polishing methods for the exhaust - I use this stuff on the tips as well and they went from black and spot rust to show room spotless. Just rub it around for a bit (it is chemically soaked fiber material) then dry/buff with a clean rag.
